I’m working on setting up a workflow where I need to send files directly from the design stage (e.g., Adobe Illustrator or Hybrid Software) to GMG’s hot folder for automated print output.
I have a few questions regarding the best approach:
- For integrating with GMG hot folders, is it better to send PDF files directly, or should I use XML job tickets for automation?
- If both are required (PDF + XML), what’s the best way to structure and integrate them?
- Has anyone here successfully set up this workflow? If yes, could you please share a basic structure or step-by-step process (such as folder setup, XML syntax, required metadata, etc.)?
- Are there any specific configurations or requirements in GMG to enable this kind of automation?
My Printer is SC5000
This setup is for a low-volume but fast-paced environment where we handle multiple jobs daily, and there’s not enough time for manual color proofing.
Thanks in advance for your help!
