CTP4 - chart generator
Hello chromix
CTP4 has very good color measure and analyze feature. it supports custom defined target which is very good, create and import the custom target data is fun for testing purpose. however, generate the print target is impossiable .
I just wondering if it has the chart generator in the future that can create some charts for i1 Pro series devices ?
i1Profiler can generates the chart for xrite devices , but lack of flexibility.
  • limitation to generate the custom chart , linearization target in 28 steps minimal
  • can’t add the seperator bar, define the seperator bar size
  • i1Profiler seems read the input data differently compared to CTP4, it is very hard to create some nice custom charts to measure
  • generate the measure chart from custom data
CTP4
i1Profiler
You can use now Freeware Babelcolor PatchTool app
thanks for your comment. PatchTool app is a nice tool, there is no further update for this software.
